REQUEST_HANDLER Class Reference
#include <request_handler.h>
Inheritance diagram for REQUEST_HANDLER:
Inheritance graph
[legend]
List of all members.
Public Member Functions
 REQUEST_HANDLER (std::map< string, JOB * > jobs)
virtual ~REQUEST_HANDLER ()
int request_handler_code (int argc, char *argv[])
 Process the request. Then reply with tasks.
virtual void process_request (m_task_t request)=0
void print_workload_status ()
Static Public Member Functions
static int find_free_channel ()
static void lock_channel (int channel)
static void release_channel (int channel)
Static Public Attributes
static std::map< int, bool > channel_table
 Value is true if channel is free; false otherwise.
Protected Attributes
Static Private Member Functions
static void init_channel_table ()
Constructor & Destructor Documentation
REQUEST_HANDLER::REQUEST_HANDLER std::map< string, JOB * >  jobs  )
virtual REQUEST_HANDLER::~REQUEST_HANDLER  )  [inline, virtual]
Member Function Documentation
int REQUEST_HANDLER::find_free_channel  )  [static]
static void REQUEST_HANDLER::init_channel_table  )  [static, private]
void REQUEST_HANDLER::lock_channel int  channel  )  [static]
void REQUEST_HANDLER::print_workload_status  )
virtual void REQUEST_HANDLER::process_request m_task_t  request  )  [pure virtual]
Implemented in REQUEST_HANDLER_BOINC.
void REQUEST_HANDLER::release_channel int  channel  )  [static]
int REQUEST_HANDLER::request_handler_code int  argc,
char *  argv[]
Member Data Documentation
std::map< int, bool > REQUEST_HANDLER::channel_table [static]
ASSUMES INITIALIZATION DONE IN MAIN
std::map<string, JOB *> REQUEST_HANDLER::jobs [protected]
The documentation for this class was generated from the following files:
Generated on Mon Mar 12 16:22:04 2007 for SimBOINC by  doxygen 1.4.6
