PROJECT Class Reference
#include <client_types_sim.h>
Collaboration diagram for PROJECT:
Collaboration graph
[legend]
List of all members.
Public Member Functions
void update_duration_correction_factor (RESULT *)
bool contactable ()
bool runnable ()
bool downloading ()
bool potentially_runnable ()
bool nearly_runnable ()
bool overworked ()
void set_rrsim_proc_rate (double per_cpu_proc_rate, double rrs)
 PROJECT (CLIENT_STATE *gstate_ptr)
 ~PROJECT ()
void init ()
int parse_state (FILE *in)
Public Attributes
char master_url [256]
char authenticator [256]
std::string project_prefs
std::string project_specific_prefs
std::string gui_urls
double resource_share
char host_venue [256]
bool using_venue_specific_prefs
std::vector< std::string > scheduler_urls
char project_name [256]
char user_name [256]
char team_name [256]
double user_total_credit
double user_expavg_credit
double user_create_time
int rpc_seqno
int hostid
double host_total_credit
double host_expavg_credit
double host_create_time
int nrpc_failures
int master_fetch_failures
double min_rpc_time
double min_report_min_rpc_time
bool master_url_fetch_pending
bool sched_rpc_pending
bool trickle_up_pending
bool tentative
bool anonymous_platform
bool non_cpu_intensive
bool send_file_list
bool suspended_via_gui
bool dont_request_more_work
bool attached_via_acct_mgr
char code_sign_key [MAX_KEY_LEN]
double duration_correction_factor
std::vector< class RESULT * > active
std::vector< RESULT * > pending
double rrsim_proc_rate
double cpu_shortfall
int rr_sim_deadlines_missed
int deadlines_missed
double short_term_debt
double long_term_debt
double anticipated_debt
double wall_cpu_time_this_period
RESULTnext_runnable_result
int nactive_uploads
double work_request
int work_request_urgency
int nresults_returned
bool checked
Private Attributes
int file_xfer_failures_up
int file_xfer_failures_down
double next_file_xfer_up
double next_file_xfer_down
CLIENT_STATEgstate
Detailed Description
Note: gstate is a reference to CLIENT_STATE, so that code in cpu_sched.C will compile without changes syntax.
Constructor & Destructor Documentation
PROJECT::PROJECT CLIENT_STATE gstate_ptr  )
PROJECT::~PROJECT  )  [inline]
Member Function Documentation
bool PROJECT::contactable  )
bool PROJECT::downloading  )
void PROJECT::init  )
bool PROJECT::nearly_runnable  )
bool PROJECT::overworked  )
int PROJECT::parse_state FILE *  in  )
bool PROJECT::potentially_runnable  )
bool PROJECT::runnable  )
void PROJECT::set_rrsim_proc_rate double  per_cpu_proc_rate,
double  rrs
void PROJECT::update_duration_correction_factor RESULT  )
Member Data Documentation
std::vector<class RESULT*> PROJECT::active
bool PROJECT::anonymous_platform
double PROJECT::anticipated_debt
bool PROJECT::attached_via_acct_mgr
char PROJECT::authenticator[256]
bool PROJECT::checked
char PROJECT::code_sign_key[MAX_KEY_LEN]
double PROJECT::cpu_shortfall
int PROJECT::deadlines_missed
bool PROJECT::dont_request_more_work
double PROJECT::duration_correction_factor
int PROJECT::file_xfer_failures_down [private]
int PROJECT::file_xfer_failures_up [private]
CLIENT_STATE& PROJECT::gstate [private]
gstate is a reference to CLIENT_STATE, so that code in cpu_sched.C will compile without changes in syntax.
std::string PROJECT::gui_urls
double PROJECT::host_create_time
double PROJECT::host_expavg_credit
double PROJECT::host_total_credit
char PROJECT::host_venue[256]
int PROJECT::hostid
double PROJECT::long_term_debt
int PROJECT::master_fetch_failures
char PROJECT::master_url[256]
bool PROJECT::master_url_fetch_pending
double PROJECT::min_report_min_rpc_time
double PROJECT::min_rpc_time
int PROJECT::nactive_uploads
double PROJECT::next_file_xfer_down [private]
double PROJECT::next_file_xfer_up [private]
struct RESULT* PROJECT::next_runnable_result
bool PROJECT::non_cpu_intensive
int PROJECT::nresults_returned
int PROJECT::nrpc_failures
std::vector<RESULT*> PROJECT::pending
char PROJECT::project_name[256]
std::string PROJECT::project_prefs
std::string PROJECT::project_specific_prefs
double PROJECT::resource_share
int PROJECT::rpc_seqno
int PROJECT::rr_sim_deadlines_missed
double PROJECT::rrsim_proc_rate
bool PROJECT::sched_rpc_pending
std::vector<std::string> PROJECT::scheduler_urls
bool PROJECT::send_file_list
double PROJECT::short_term_debt
bool PROJECT::suspended_via_gui
char PROJECT::team_name[256]
bool PROJECT::tentative
bool PROJECT::trickle_up_pending
double PROJECT::user_create_time
double PROJECT::user_expavg_credit
char PROJECT::user_name[256]
double PROJECT::user_total_credit
bool PROJECT::using_venue_specific_prefs
double PROJECT::wall_cpu_time_this_period
double PROJECT::work_request
int PROJECT::work_request_urgency
The documentation for this class was generated from the following files:
Generated on Mon Mar 12 16:22:04 2007 for SimBOINC by  doxygen 1.4.6
