JOB Class Reference
Corresponds to a project in BOINC, from which tasks are generated for execution. More...
#include <job.h>
List of all members.
Public Member Functions
 JOB ()
int parse (FILE *in)
void clear_job ()
vector< m_task_t > get_tasks (int num_tasks_req, REPLY_DATA *reply_data)
vector< CHKPT_TASK * > get_chkpt_tasks (int num_tasks_req, REPLY_DATA *reply_data)
 create the CHKPT_TASK and returns a vector of them
WORKUNITget_wu ()
 Creates WORKUNIT based on current task counter.
RESULTget_result (CLIENT_STATE *gstate, char *wu_name)
Public Attributes
char name [256]
int task_counter
int num_tasks
double task_comp_size
double task_comm_size
int chkpt_freq
double delay_bound
std::map< string, m_task_t > task_buffer
int num_tasks_completed
int num_tasks_rem
double rsc_fpops_est
Private Member Functions
void refill_task_buffer ()
void validate ()
Detailed Description
Constructor & Destructor Documentation
JOB::JOB  )
Member Function Documentation
void JOB::clear_job  )
vector< CHKPT_TASK * > JOB::get_chkpt_tasks int  num_tasks_req,
REPLY_DATA reply_data
RESULT * JOB::get_result CLIENT_STATE gstate,
char *  wu_name
should only be called once per task.
vector< m_task_t > JOB::get_tasks int  num_tasks_req,
WORKUNIT * JOB::get_wu  )
int JOB::parse FILE *  in  )
void JOB::refill_task_buffer  )  [private]
void JOB::validate  )  [private]
Member Data Documentation
int JOB::chkpt_freq
double JOB::delay_bound
relative from the time the RESULT is created, when it's about to be sent to the client
char JOB::name[256]
name of the project
int JOB::num_tasks
int JOB::num_tasks_completed
int JOB::num_tasks_rem
num tasks not assigned
double JOB::rsc_fpops_est
std::map<string, m_task_t> JOB::task_buffer
double JOB::task_comm_size
double JOB::task_comp_size
int JOB::task_counter
The documentation for this class was generated from the following files:
Generated on Mon Mar 12 16:22:03 2007 for SimBOINC by  doxygen 1.4.6
