CHKPT_TASK Class Reference
Implements a task that checkpoints periodically. More...
#include <chkpt_task.h>
List of all members.
Public Member Functions
 CHKPT_TASK (const char *project_name, const char *name, double compute_duration, double message_size, void *data, int num_segments)
 ~CHKPT_TASK ()
void * get_data ()
MSG_error_t execute ()
MSG_error_t cancel ()
const char * get_name ()
void set_cpu_no (int cpu_no)
int get_cpu_no ()
bool is_primary_host (m_host_t host)
void update_project_metrics ()
Public Attributes
string project_name
string task_name
double task_compute_duration
double task_message_size
void * task_data
m_task_t subtask_curr
double subtask_compute_duration
double subtask_message_size
void * subtask_data
int num_segments
int num_segments_remaining
int num_segments_completed
int num_segments_attempts
bool cancelled
bool completed
double wall_start_time
double wall_stop_time
double wall_completion_time
bool first_execution
int cpu_no
double report_deadline
Detailed Description
Note one cannout use MSG to send or receive a checkpoint task (e.g. we do not implement the equivalent of MSG_task_get_sender, MSG_task_get_source, MSG_process_suspend).
Constructor & Destructor Documentation
CHKPT_TASK::CHKPT_TASK const char *  project_name,
const char *  name,
void *  data,
int  num_segments
CHKPT_TASK::~CHKPT_TASK  )
Member Function Documentation
MSG_error_t CHKPT_TASK::cancel  )
if a (sub)task is executing, cancel it.
Returns:
state of chkpt task as an MSG_error_t
MSG_error_t CHKPT_TASK::execute  )
int CHKPT_TASK::get_cpu_no  )
void * CHKPT_TASK::get_data  )
const char * CHKPT_TASK::get_name  )
bool CHKPT_TASK::is_primary_host m_host_t  host  )
void CHKPT_TASK::set_cpu_no int  cpu_no  )
void CHKPT_TASK::update_project_metrics  )
Assumes that it is only called when a task is completed and wall_completion_time is set
Member Data Documentation
bool CHKPT_TASK::cancelled
bool CHKPT_TASK::completed
int CHKPT_TASK::cpu_no
cpu id that task is executing on
bool CHKPT_TASK::first_execution
whether this is the first time we have tried to execute the task
int CHKPT_TASK::num_segments
int CHKPT_TASK::num_segments_attempts
number of times we've tried to complete segments
int CHKPT_TASK::num_segments_completed
int CHKPT_TASK::num_segments_remaining
string CHKPT_TASK::project_name
double CHKPT_TASK::report_deadline
set in RESULT::set_chkpt_task
double CHKPT_TASK::subtask_compute_duration
m_task_t CHKPT_TASK::subtask_curr
subtask that the host is currently executing
void* CHKPT_TASK::subtask_data
double CHKPT_TASK::subtask_message_size
double CHKPT_TASK::task_compute_duration
void* CHKPT_TASK::task_data
double CHKPT_TASK::task_message_size
string CHKPT_TASK::task_name
double CHKPT_TASK::wall_completion_time
completion time, i.e., time elapsed between wall_start_time and wall_stop_time
double CHKPT_TASK::wall_start_time
start time according to simulated wall clock time
double CHKPT_TASK::wall_stop_time
stop time according to simulated wall clock time
The documentation for this class was generated from the following files:
Generated on Mon Mar 12 16:22:02 2007 for SimBOINC by  doxygen 1.4.6
